Fuel Injector help.
  • rvaughnp
    • 136
    Fuel Injector help.
    Need help in pulling injector control "block" off.
    I understand that the 4 bolts allow the injectors to pop off. This block is blocking me from getting the bolts off.
    So...
    Thanks.
  • rvaughnp
    • 136
    Found it.
    Sorry, guess i should have researched a little more.
    Found this on another site.
    Step 5: Note that each fuel injector has a retention clip which fastens the electrical box to the injectors. Using a flat head screw driver pry one side of the metal clip to the side of the connection. It does not have to be removed, just offset to release the connection.
    Off to get cleaned up.
      • 34847
      you don't need a screwdriver on that style injector harness. just pull it up, it will come off.
      • rvaughnp
        • 136
        Nando, all due respect... i don't or didn't see that clip just popping off. There is a molded stop labeled "here" in yellow; that the clip must be removed to slide off.
        I understand that the fuel rail just pops off.
          • 34847
          trust me, done it many times. pull up.
