oil on #6 spark plug
  • pwagon717
    • Jun 2007
    • 1197
    I am about to buy this 1991 325is from a friend. He says that the #6 spark plug is fouling out due to oil on the part that gets spark. I did a search on both here and bimmerforums. Only thing came up with was a valve cover gasket leak. I want to be sure, before buying this and having to do a valve job or a full rebuild. The car had a full rebuild 2-3 years ago. Any help or comments would be great.
    _________
    Rep Savannah Crew
  • ubernasty
    • Jan 2009
    • 2749
    what shape is the rest of the car in.. if its nice and already has tasteful mods then buy it and just get a used motor or rebuilt head.
    • pwagon717
      • Jun 2007
      • 1197
      The car is perfect. He bought the car $7,500 2 years back. Wants $4k in the condition it is in now, which is still flawless.
      _________
      Rep Savannah Crew
      • Atreus
        • 1846
        could be the VC gasket. have you even checked it out yet? bring a spark plug.. just one good one, lol. see how it runs...
        1991 325iC - Mauritsblau sumthin metallic blue. DEAD
        1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
        1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
        1991 325iC - Calypsorot Metallic
        1994 540i - Granitsilber
        Originally posted by scabzzzz
        I've had blunts cock in my mouth, but I'm not gay.
          • 34827
          how exactly do you guys think a VC leak is going to get into the combustion chamber and foul a spark plug?
          • pwagon717
            • Jun 2007
            • 1197
            ^^lol. You had me laughing Nando. What you think it is, Mr. Moderator?
            _________
            Rep Savannah Crew
            • slo325i
              • 417
              Sounds like worn piston ring. Check the compression of that motor before you spend the money. For $4k you should/could get a pretty nice E30. Decent body shape is all well and good but replacing the motor for a fully rebuilt one could cost good money/headaches.
              '89 325i - Totaled... good bye my love...
              '87 327i budget stroker - SOLD!!!
              '92 240sx - ca18det powered drift toy - SOLD!!!
              '89 325i - coupe - NEW daily
              '96 Audi A6 Quattro- Grocery getter/baby hauler
              '99 Busa - weekend wheelie monster
                • 34827
                I don't know, but 3 seconds of neurons firing in my little brain tells me it's impossible for a VC gasket leak to foul a spark plug. ;)
                try asking jlevie
                • QUKBMER
                  • 8178
                  It is piston rings or valve stem seal/valve guide.Pull one of the other spark plugs and if they look pretty new and the #6 is crap,consider valve job or motor rebuild my friend.:???:
                  • pwagon717
                    • Jun 2007
                    • 1197
                    try asking jlevie
                    Yea he replied to me on bimmerforums.
                    _________
                    Rep Savannah Crew
                    • LannieDuncan3
                      • Jul 2010
                      • 6
                      i can tell you right now its not the vc gasket. if it was that it would be leaking on to the ground not into the dam combustion chamber. it very unlikely only one ring is going to were out so thats not even a question. its eather the valve seal or the oil pick up tube o ring is busted. mine is doing the same thing in the #5 cylinder. i just havent taken the time to fix it
                      • gearheadE30
                        • Jun 2007
                        • 3734
                        fwiw check the oil level too. I made the mistake of filling my car on a hill and didn't realize it after installing the turbo, and apparently I was on an equivalent hill when I checked again after 10 minutes of driving. Eventually fouled #1, and I mistook the blue smoke and running on 3 cyliners for a blown HG. Turned out to have a bout a quarter quart over full. Hasn't done it since draining out some oil.
                        Project M42 Turbo
                        • payney8
                          • Jun 2007
                          • 899
                          Yeah, listen to nando and gearhead. Check oil level as he could be over filling it or not inserting the dipstick all the way. Simple mistake that can cause excessive crank splash. Otherwise id be looking at getting a compression test and checking the valve stem seals.
                          • Adrian_Visser
                            • Jun 2006
                            • 2823
                            Valve guide or valve stem seal. A leakdown/ compression test may or may not show any indication of this, oil burning on the spark plug is kind of a dead giveaway I would say. A head rebuild isn't that expensive and is a good bargaining tool when buying the car, talk him down a bit on it if the rest of the car is in good shape.
                            '89 Alpine S52 with goodies
                            • pilotskillse30
                              • Dec 2006
                              • 1957
                              would valve stem seal or guide cause excessive oil burn cause I just got home from Afghanistan and my car is burning like a quart a week, under acceleration I put out smoke. I just started having a hesitation in acceleration above 4000rpms, so I pulled the spark plug in piston #1 and my spark plug looked like it was growing alligator skin from all the oil burn up, two looked similar haven't removed the others to see, will get back to work on it...just wanted to see if you guys have an answer...OH PWAGAON i'm back in town maybe you can help me out, mail me your number cause I have a new phone and I don't have it.
