I know this has probably been covered a dozen times but M20 stroker clarification
  • SeriousBusiness
    • 428
    I am looking at buying a complete 2.7 short block from a guy on the forums here and also a set of "i" rods from him. Someone told me to use the ETA crank, i rods, and custom 86mm pistons for 2.8L of displacement with the head thats in my 325is right now. I would be building the short block on the side so I don't have my car down so long and then swapping the head on when I'm ready to pull the motor from my car.
    Am I going about it right? Or do I use the ETA crank/rods with 86mm pistons and forget about the i rods? I know there is probably a faq that I missed but I'm on the cell phone right now and this is the best I can do.
    Thanks guys.
    1985 RX7 - Badassery Exemplified.
    1989 325is
    -Tom
    • 34837
    if you are getting 86mm pistons, definitely use the 135mm rods. 130mm would only be used on a ghetto/frankenstein 2.7l.
    • SeriousBusiness
      • 428
      Yeah I plan on getting 86mm pistons to match the 885 head and to get the compression closer to 10:1 (if possible).
      Any opinions on that? My main motivator here is price. I'm getting a good deal on the bottom end parts, and aside from the pistons, the whole build will be pretty budget-minded since I can do the work (aside from machine) myself.
      EDIT
      It will be budget-minded but I will not be cutting corners. I like to do things right. My b25 is just clapped out and tired.
      1989 325is
      -Tom
      • SpecM
        • Oct 2005
        • 4531
        His point is: if you're going to buying custom pistons anyway, get some with a shorter pin-to-crown height so you can use 135mm rods. Really, you want the longer rods with the higher compression (and cam if you do so).
        maybe pick up some second-hand s50/52 rods (lighter, stronger 135mm)
        1989 cirrisblau-metallic 325i
