stroking an m20b23
  • The Humjet
    • Jun 2010
    • 528
    stroking an m20b23
    I was wandering if this combo could work for an m20b23:
    -m50 crank
    -stock rods
    -m20b25 pistons (stock block gets bored 84mm)
    my aim is to have a low compression ratio so i can turbo this engine, and I know I could just simply buy an eta block and lower the compression ratio but here in Australia they're not easy to come by.
    If you think this is a completely stupid idea, do tell some other options I could go.
  • digger
    • Nov 2005
    • 6213
    Isn't the 323i crank bigger than the M50? therefore you would be destroking
    • The Humjet
      • Jun 2010
      • 528
      Yer your actualy right my bad, how bout the pistons could bore it out the block and put 325i pistons would that increase or decrease the compression ratio
