Head Bolt Question!?
  • 6gen91
    • 712
    In the bentley manual, theres a sequence to retorquing your head bolts down after taking them off. should i follow this sequence or buy new head bolts? and if so, can someone throw me a link and prices,
    thanks alot
    Mike
  • Dj Buttchug
    • Jun 2010
    • 7686
    follow the sequence and get some new bolts. the old ones stretch and are no good ususally
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • 6gen91
      • 712
      autohousaz has a set of OE's for $20. are those legit?
        Any bolt whose torque specification is in angles is a torque to yield bolt and thus is a one-time use fastener.
        • Scallywagon
          • 1200
          http://www.pelicanparts.com/cgi-bin/...0%281984-91%29
          And you go in order once to 22ft/lbs then you go in order 90* then you go in order 90* again
          ( f ; _ ; )f
          • 6gen91
            • 712
            those are the exact ones autohausaz has! but for $1.00 more lmfao. ill def go with those. thanks
