A few parts I'm confused on
  • Scallywagon
    • 1200
    What is the special elbow shaped vacuum hose that comes out of the bottom of the throttle body and plugs into the electronics / black canister with 2 nipples on it? Also, are there gaskets for these two connections:
    Thermostat housing, not the one to the head, but to the top part of the housing
    Passenger side of the intake manifold that connects to the fuel rail
    ( f ; _ ; )f
  • Scallywagon
    • 1200
    bump
    ( f ; _ ; )f
      • 34839
      charcol canister and evaporative purge valve
      there's an o-ring for the thermostat, but no gasket other than where the housing attaches to the head.
      not sure what you mean on the fuel rail.
      • hurttech
        • 237
        Vacuum line to the fuel pressure regulator.
        • Scallywagon
          • 1200
          yes this, connects to the FPR via vacuum hose to the pass. side of the intake mani and has that bracket in front of it too connected to the valve cover, no gasket for that either?
          ( f ; _ ; )f
          • Scallywagon
            • 1200
            so I'm looking for evaporative purge valve vacuum hose then?
            ( f ; _ ; )f
            • hurttech
              • 237
              Real OEM is showing a gasket goes there, but no part number is listed. I'm afraid to crack my own to look.
              Hes talking about that FYI. Anyone know?
              • Danny
                • 14216
                Just use a cereal box.
                • Adrian_Visser
                  • Jun 2006
                  • 2823
                  Well you can buy gasket sheets that you can cut your own shapes out of too.
                  '89 Alpine S52 with goodies
                  • Scallywagon
                    • 1200
                    good shit meroki
                    ( f ; _ ; )f
