Fuel injector electrical harness
  • jaywood
    • Jul 2010
    • 4528
    I am cleaning/replacing o rings on my fuel injectors and I can't figure out how the electrical harness disconnects. This is the other end of the harness which plugs in here:
    How do I get that plug out?
  • Sagaris
    • Sep 2009
    • 2243
    the bottom half of that plug (below the metal bracket that is holding it in place) twists 90 degrees or so and unlocks just like the oxygen sensor harness. Check out the oxygen sensor harness if you dont know what I mean. It is much easier to get to and will give you a clue as to what needs to happen.
    • jaywood
      • Jul 2010
      • 4528
      I got the bottom part to twist off, and it is no longer plugged in to anything. Now how do I get it off of the metal bracket?
      • jaywood
        • Jul 2010
        • 4528
        Nevermind. Got it. O2 sensor helped a lot.
        Thanks for the help Sagaris.
        • jaywood
          • Jul 2010
          • 4528
          Nvm, got it again
          • jaywood
            • Jul 2010
            • 4528
            Ok. These little yellow heads seem to be cracking.
            When I wiped them off little pieces broke off here and there.
            Are they replaceable?
              • 34839
              yes, they're standard bosch pintle caps, get new ones with some o-rings.
              • jaywood
                • Jul 2010
                • 4528
                How do the originals come off?
                • u3b3rg33k
                  • Jan 2010
                  • 2452
                  Pull.
                  Ich gehöre nicht zur Baader-Meinhof Gruppe
                  Originally posted by Top Gear
                  Just imagine waking up and remembering you're Mexican.
                  Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
