Driving in to work today and enjoying my self, shifted in to 5th and
got a spudder in the motor..
Just that quick...
First thing that ran through my head way i broke a rocker arm...
pulled over. Turned off the car. looked over everything found nothing wrong. So I started the car. turned right on, but with a flutter..
Next thought was fouled plugs.. pulled and plugwires and found #2 had no change.. got home changed all the plugs started the car right up, but still, has a flutter... Check elc. I got Spark!
Pulled #2 and found alot of oil.. soked piston with carb cleaner and turned over the motor with plug out to blow the shit out..
replaced plug.. Ran perfact for about 4sec. Then the flutter came back..
Pulled the plug.. more oil.... not alot but enough to foul the plug...
????????Oh and get this as i was driving home I saw no smoke from the tailpipe or while running it in my garage got no smoke???????
Could it be a head gasket..?
Valve guide?
Injector??
Please need help..
thx
jer
Just that quick...
Valve guide?
Injector??
Please need help..
thx
jer
