Cleaning MAF
  • Zinno_e30
    • Jul 2010
    • 553
    Cleaning MAF
    Any insight onto how to clean my Mass air flow sensor? My car is hesitating and surging as it drives. It could be the Idle control but I doubt it. Before spending $400 on a new MAF sensor I was hoping I could clean it and see if that would fix the problem. It's an 87 325e with 220k
  • IronJoe
    • 2275
    I've used this stuff in the past. Works pretty well.
    http://www.amazon.com/CRC-05110-Mass.../dp/B000J19XSA
    Found at Autozone or similar parts store.
    '89 Schwarz E30 M3 Cabriolet Build
    • Zinno_e30
      • Jul 2010
      • 553
      Thanks, anyone know how to remove it without damaging it?
        • 34844
        you don't have a Mass Airflow Sensor. it's an AFM.
        Unbolt it? Unless you drop it from a 10 story window, you aren't going to break it by taking it out of the car. it's made of metal.
        • Zinno_e30
          • Jul 2010
          • 553
          Yeah, you're right.
          What else do I disconnect besides the connector and large bolt?
            To get the AFM out, remove the AFM and air box from the car. In addition to the bolt you can see there are four nuts inside the air box. With the AFM separated from the air box use carb cleaner on the AFM. Lube the vane pivot points with 3-in-1 oil.
            • Zinno_e30
              • Jul 2010
              • 553
              Which part am I cleaning?
              • lolcantturn
                • 4588
                Look inside the air box. There are 4 bolts. There's also a tunnel-looking thing before you remove those four bolts. You're going to know when you're looking at the AFM, I guarantee it.
                Originally posted by TSI
                OEM+
                • Zinno_e30
                  • Jul 2010
                  • 553
                  Yeah, I see the 4 bolts. How does the tunnel looking thing come off? Feels like it's going to snap when I try to pry it off
                  • iwantspeed
                    • 3164
                    it clips in
                    Project
                    Parts for Sale
                    Feedback
                    YouTube Channel
                    • StereoInstaller1
                      GAS
                      • 22679
                      Why the hell did you remove it? The part you wanna clean is under that plastic cap, and is easier to clean if in place. Look for something called a "trace" and if you can't find it under that cap (yes it is glued on, you had best do the same when done, too) you need to sell your fucking car and get a bus pass or a Camry.
                      Closing SOON!
                      Thanks for 10 years of fun!
                      • lolcantturn
                        • 4588
                        don't be a meanieface. It's not like removing the airbox takes more than a minute.
                        But yeah do what he said......and use your head as much as you can before going on r3v to ask how to get the tunnel out..it's pretty obvious it's clipped in.
                        OEM+
                        • KenC
                          King of Kegstands
                          • 14396
                          Spray the board with some electrical cleaner. Make sure the flap moves freely too.
                          Originally posted by Gruelius
                          • Zinno_e30
                            • Jul 2010
                            • 553
                            I appreciate all the input, thank you all.
