engine install... it lives
  • NC325iC
    • Mar 2004
    • 6565
    hey guys
    my parents just revealed to me my graduation present, as you can tell by what section this is in it is an M20 Stroker or so they say
    They told me that it has 8000 miles on it with 200 or so hp
    i dont know if it is completely true or not but i have requested a list of whats been done.
    more to come
  • NC325iC
    • Mar 2004
    • 6565
    oh yeah forgot i need a write-up on swappin m20s for m20s preferably step by step detailed... and accesory swapping
    thanks
    • NC325iC
      • Mar 2004
      • 6565
      right well my grandfather got an email back from the guy he got the engine from (a close friend of his) turns out its been stroked to 2954cc has a schrick cam in it (ill get the numbers tommorow along with a pic under the valve cover) some kind of light weight pistons a late m3 crank and a piston ring setup that apparently uses some oil on purpose. anyone know about that?
      • DEV0 E30
        • Oct 2004
        • 8904
        Good luck is about as much help I can offer to you.
        I'm sure someone else will chime in and help you.
        • Bryson
          • 1490
          m20->m20 swap, unplug, plug-in. What else would you like to know?
          • Chris E30 Cab
            • 866
            Congrats on graduating, and congrats on the 3.0L stroker ;) You'll love it! And yes it is just as simple as unplugging and plugging everything back in.......except perhaps the wiring harness, as you need to match up the engine harness to your ECU....ie, same Motronic.
            EDIT: and if you have an old clutch, you might want to get a new stock 325i one ;)
            • NC325iC
              • Mar 2004
              • 6565
              it came with everything ecu and harness included
              • RCWells
                • 3589
                Lucky. :|
                [THE 501 club - Founding Member]
                • NC325iC
                  • Mar 2004
                  • 6565
                  i know :D
                  • Stu Mc
                    • 4083
                    I helped your grandfather load it in his F-150.
                    Your cabby will haul ass, but you need to get a 4.11 rear end to take full advantage of that motor, IMO.
                    • BS87
                      • 1606
                      Give us specs stu!
                      • Stu Mc
                        • 4083
                        • BS87
                          • 1606
                          Sweet.
                          • SlammedE30
                            • 741
                            Almost identical to my old motor (albeit slightly higher compression), and mine made 186rwhp and 192rwtrq (w/ stock AFM and engine management, btw). So with a similar setup to Jordan's (HFM and Unichip) I wouldn't put 200rwhp past this car. Have fun and be careful in the wet!!
                            -Ted
                            • NC325iC
                              • Mar 2004
                              • 6565
                              no shit
                              thanks for the help
