engine install... it lives
  • NC325iC
    • Mar 2004
    • 6565
    #31
    also which motormounts should i get i know there are some other than e30s that will work are they the ones for the m30?
    • NC325iC
      • Mar 2004
      • 6565
      #32
      ok thanks guys
      • NC325iC
        • Mar 2004
        • 6565
        #33
        done with the install, ive driven it around a few times and taken it up to redline and damn its got a nasty growl to it.
        only problems
        got a 1222 fault code- ive been told it is most likely a vacuum leak
        and crappy or no idle- lines up with vac leak
        any help on how to find the leak would be nice
        • NC325iC
          • Mar 2004
          • 6565
          #34
          noone wants to help me do you
          • RCWells
            • 3589
            #35
            Dude, if I could I would. I am a novice mechanic at best.
            Somebody here should know how though. Anybody?>
            [THE 501 club - Founding Member]
            • DEV0 E30
              • Oct 2004
              • 8873
              #36
              Does your rubber intake boot have a slit in it?
              That can make the idle horrible.
              Maybe it was damaged when you were putting things back together.
              • NC325iC
                • Mar 2004
                • 6565
                #37
                i donno is there anyway to check besides visual inspection might miss it
                  • 34839
                  #38
                  take it off and stretch it out. if there are any cracks/holes you will know.
                  • Bimmerfanatik
                    • May 2004
                    • 5349
                    #39
                    Or...spray parts cleaner on it. If you hear a change in the idle, you found your leak. Do this around the intake mani gaskets, tb gasket, etc. Great way to find out where a leak is coming from with little work.
                      • 34839
                      #40
                      meh, it takes like 5 minutes to remove, and I'd rather not get my engine bay all oily. ;)
                      • NC325iC
                        • Mar 2004
                        • 6565
                        #41
                        yeah but it takes alot of effort to put back on the m30 afm
                          • 37829
                          #42
                          Carb/brake cleaner is hardly oily
                          Use that method
                          Classic BMW Specialists
                          Grover Beach, CA
                          www.BimmerHeads.com
                          • rs4pro3
                            • 5808
                            #43
                            A spray bottle of water works good also.
                            85 325e 2.7 ITB'd stroker
                            • NC325iC
                              • Mar 2004
                              • 6565
                              #44
                              yeah ok derrr
                              • Bimmerfanatik
                                • May 2004
                                • 5349
                                #45
                                Use that method
                                Oily? It's parts cleaner. If anything your car will look nicer :)
