I've had this problem for a while now but its been getting worse so time to fix it before im stuck in a parking lot and 11 o'clock at night, However i've noticed if i leave the car out for the night it starts right up more often. If i leave it in or if the engine is still warm i get the problem a lot more often it seams to help if the hold the throttle wide open while cranking also. So why would it start better in the cold? Today i went to start it which its been in the garage and not started for at least 4 day and i couldn't get it to start. i jumped the fuel pump to test and and it worked. switched relay and no fix pulled return line of and had fuel and pressure, could it be electrical, or possibibly its not holding pressure in the line like if there is a check valve in the line. So what should be the next thing to look into here any help would be nice
Thanks, Stevan
Thanks, Stevan
