dumb overheating AGAIN
  • stumble_t
    • Aug 2009
    • 759
    Is the belt on the WP new and tensioned properly?
    [IMG]http://www.r3vlimited.com/board/
    • redhatpat
      • Aug 2005
      • 656
      Sounds like a bad fan clutch.
      • einstein57
        • Jun 2007
        • 10780
        I'd say you still have air in the system. Have you tried blowing in the overflow tank while the bleeder is open? I took me 30 minutes to bleed it after i took off the head. I just kept doing it over and over till the heater finally got hot.
        www.gecoils.com
        • lolcantturn
          • 4588
          Yes
          You think theres a huge air bubble in my radiator? What do you mean blowing in the overflow tank? The heat in my car is already a nice temperature.
          Originally posted by TSI
          OEM+
          • lolcantturn
            • 4588
            I'm assuming my thermostat is working..because without it my car just plain overheats.
            I'm going to flush my radiator tomorrow and put new coolant and bleed it while squeezing the lower radiator hose and hope for the best..because I simply don't see how a new radiator and a new thermostat could account for lack of circulation.
            OEM+
            • Danny
              • 14216
              New thermo and fan clutch.
              Go!
              • lolcantturn
                • 4588
                Go!
                Something with the thermo or radiator is definitely screwy, fan clutch I suspect is next.
                OEM+
                • Danny
                  • 14216
                  Just take it out and spray a hose though the fins and also though the inlet AND the outlet holes, it might help.
                  • lolcantturn
                    • 4588
                    Haha I wish I lived in cali..I could do that outside without worrying of freezing. But yeah I'll do that!
                    OEM+
                    • CoryMStew
                      • Dec 2010
                      • 62
                      i suggest taking one of a e28 because it spins with the engine instead of a switch to tell it when to turn on. I put one in when my fan clutch died. The car wont go over a little over 1/4 of the way on the temp gauge. It puts more strain on the engine but it makes it sound more aggressive if your standing in front of the car.
                      • Eecen
                        • Jun 2010
                        • 1235
                        Really?
                        • lolcantturn
                          • 4588
                          :neutral:
                          Cold engine= running rich= running poopy= shitty gas mileage= unhealthy
                          OEM+
                          • einstein57
                            • Jun 2007
                            • 10780
                            you take off the overflow cap and blow into it with the bleader open.
                            www.gecoils.com
                            • CoryMStew
                              • Dec 2010
                              • 62
                              Yeah really
                              • lolcantturn
                                • 4588
                                I cleaned out my radiator..for a new radiator it had a lot of black gunk in it.
                                checked my hoses, they seemed good
                                rebled, bled, and bled again
                                now it flickers between this position
                                and the middle, on idle. It'll get to that position, and within 3 or so seconds it'll go back to halfway, 5 seconds passes and it goes back to that position.
                                I guess I'm ok with it, it was a lot worse before.
                                OEM+
