M20B23 motor and Getrag 5 speed from a 1985 E30
  • black bmw 318
    • Sep 2004
    • 16
    hi guys
    i can get a M20B23 1985 motor very cheap.
    i was thinking about using it as a starting block to build upon.
    what would you recommend? should i put on a late model i head?
    what else will i then need to change?
    i assume crank, pistons? i ecu and injectors?
    or would i be better off looking for a complete late model i engine and just impoving on that?
    any help appreciated
    cheers
  • AdamF 88iS
    • 2051
    Use the head you have, get E rods and pistons, and a TD or E crank.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
    • bkelsey86
      • 1173
      werd 8)
      • black bmw 318
        • Sep 2004
        • 16
        confused now...
        i dont have an "i" head, but i can get a cheap 85 M20B23 motor.
        should i put an "i" head on it?
        what else would i need, pistons?
          • 34844
          they are saying to use your B23 head on the equivalent of an eta block.
          • AdamF 88iS
            • 2051
            The b23 head is special. Use that with a b27 bottom end.
            Adam Fogg- '88 M3
            • Switch
              • Oct 2004
              • 158
              question...... *rasies hand steadily*
              the 2.5 head has larger valves ect ect. then the 2.3 head (right?)
              so wouldn;t the 2.5 head be a better canidate for a stroker....
              whats so special about the 2.3 head?
              i am in same position, i can also get a b23 head for cheap..
              </img>
              Schnitzel Not Rice....
              • decay
                • 5637
                search on keyword "731".
                also, i'll be upping my valves to i-sized before mine goes in on top of an eta block.
                past:
                1989 325is (learner shitbox)
                1986 325e (turbo dorito)
                1991 318ic (5-lug ITB)
                1985 323i baur
                current:
                  • 34844
                  sure but you can't just bolt it onto an e block. it would be easier to get a cam and oversized valves for the 2.3 head.
                  • Switch
                    • Oct 2004
                    • 158
                    searched for 731... so the euro 323 head has I sized valves..... and a higher lift on the cam.. (which would give it.. more high end??)
                    thats kinda cool... so its basically an 2.5 head with a stock higher cam...
                    so.. why won;t it just bolt onto an eta? (or super eta?) low compression issues?
                    </img>
                    • decay
                      • 5637
                      it would be more correct to say it's an eta head with i port passages. valves are the same as an eta, but intake manifold gaskets are the same as an i.
                      it will bolt up to an eta, super-eta or i blocks are what it's not compatible with.
                      compression ratio of the 731/eta combo has been reported here at ~9.8:1.
                      past:
                      1985 323i baur
                      current:
                      • Switch
                        • Oct 2004
                        • 158
                        hmm, so basically mixing the two would give you the I head + eta block w/ higher compression..... grr. i guess the thing thats confusing me is.. why chose this method over i + eta w/ custom pstons (super eta)
                        what kind of power can one expect with 2.3 head plus eta bottom....?
                        sry if i am asking alot of questions...
                        </img>
                          • 34844
                          because custom pistons are around $800+ vs just bolting the 323 head onto the e block.
                          of course getting a 323 head is not easy so most people go custom..
                          • Switch
                            • Oct 2004
                            • 158
                            hmm... and power difference between 731 head to custom pistons ect....
                            bascially..
                            would 731 head and eta bottom give e more power. low and high then a stock 2.5.... :)
                            </img>
                            • decay
                              • 5637
                              displacement goes from 2494cc to 2692cc
                              compression ratio goes from 8.8:1 to 9.8:1
                              that should tell you all you need to know.
                              i found my 731 head after about a month of searching. they're out there, you just have to be patient/vigilant and have the money ready to throw at one when it pops up.
                              past:
                              1985 323i baur
                              current:
