I've been having this really weird problem for about 2 years now and still havent fixed it. What happens is when it's cold and wet out (sub 40F temperatures), the engine will try to cut off and choke out. usually it will just try to die with a very forceful jerk almost like hitting a wall, then, a moment later, it'll keep going. Sometimes it'll happen once then not do it again for a few moments, other times, it'll do it over and over again till it has no power at all and i have to downshift to 3rd or 4th just to keep the RPMs up to maintain highway speeds.
Last winter, i could seem to keep this from happening if i kept the RPMs over 3500 but it doesnt seem to want to work this winter like that. There has been one other issue that just started happening this fall and I dont know if it's related. Sometimes, while the car is still cold, I'll turn the headlights on and there will be a noticeable drop in power. Once it was enough to stall the engine out.
so far replaced to try and fix this:
Cap
rotor
plugs
wires
coolant temp sensor on thermostat
alternator
I'm at a loss of what to do and i cant not drive my e30 since it's my only car. Any suggestions on what to try next? I'm considering a wiring harness soon to see if that does anything.
Cap
rotor
plugs
wires
alternator
