diesel crank in a m20?
  • e30gentry
    • 608
    What would an old 5 series diesel crank do in a M20 engine.
  • einstein57
    • Jun 2007
    • 10780
    Search function perhaps
    www.gecoils.com
    • felix
      • Apr 2009
      • 18
      Same result as an eta crank.
        • 34839
        it will add 5lbs of rotational mass over the eta crank for no real benefit. it also usually costs 4-5x as much.
        • ieatpeople
          • Mar 2008
          • 883
          i have heard that its stronger than an eta crank.
          Originally posted by BillBrasky
          That's like Vlad challenging Chip Foose to a car painting contest.
          Originally posted by acolella76
          i'm pretty sure 'Phillis' is short for syphilis
          2007 CVPI, stock and slow
          1994 tercel, 5efhe swap, i/h/e
          1984 t-type, 5.3/th350 swap in progress
          My newest addition:
          Rebecca Arlene, born 4/19/2013
            • 34839
            you heard wrong
            • peteb3
              • Nov 2009
              • 158
              524td crank is forged steel, eta and i cranks are cast
              • SpecM
                • Oct 2005
                • 4531
                and have you ever heard of an i or eta crank breaking?
                1989 cirrisblau-metallic 325i
                • briansjacobs
                  • 1278
                  It is funny I have always heard there was 5 pounds difference between the cranks, I weighed an E and TD on the same scale within minutes and there was 1 pound between them.
                  At some point I am going to get another TD crank and have it knife edged, that is one place I saved money on this build but plan to address later.
                  Brian Jacobs
                  • briansjacobs
                    • 1278
                    breaking no, bending yes.
                    Brian Jacobs
                      • 34839
                      yes, it's forged rather than cast, but it's of no real benefit.
                      if you want forged and want to spend $300, get an S52 crank.
                      • briansjacobs
                        • 1278
                        I wonder if I could just replace crank and rods or if I would need pistons as well. I am running TD crank,I rods, ross custom pistons.
                        Brian Jacobs
                          • 34839
                          you definitely need pistons with the S52 crank
                          • peteb3
                            • Nov 2009
                            • 158
                            Let's answer the question he asked:
                            a diesel crank in an M20 would be most likely used for a stroker build (a la Alpina B3 2.7)
                            If it's an "i" M20, you would need different pistons as well, to complete the build, you could use the stock M20 "i" rods though.
                            • LJ851
                              • 7919
                              Keep in mind that the diesel crank has much rougher life than an eta crank. WAY high compression and large low rpm torque numbers (for an m20). My understanding is that the eta crank is good to 6000k or so.
                              Lorin
                              The M30 is God's engine.
