Though I would document what I've found and done:
The situation:
Tests and changes so far:
I edited the cranks sensor test because I tested the wrong end of the plug - yes, sometimes I miss the details....
The situation:
- The car would start right up from cold, no problem
- Strong smell of gas from the exhaust, this means rich to me
- Idle would jump up and down from 700-1500 after maybe 30 seconds or so
- Engine would eventually stall out and maybe restart, maybe not
- Spark plugs were black and carbon'd up
- Read my Bentleys
- Tested the water temp sensor - ohms test within spec
- Tested the crank position sensor - ohms test within spec
- Tested idle air control valve - ohms test within spec and functions properly
- Changed spark plugs - set gap about 0.030" - NO IDLE IMPROVEMENT
- Changed out the fuel pressure regulator and vacuum line to intake manifold - I was going to test the pressure, but this was easier than renting the tester, testing and returning it... - NO IDLE IMPROVEMENT
- Tested the throttle position sensor - no continuity when closed, continuity when opened - adjusted this all the way - IDLES BETTER NOW
- Got CEL to work and stomp tested - no codes 1444
- Wife wants to know whats so interesting in that book
- Idles OK at 800 rpm, still has a little skip every few seconds - this got better after the TPS adjustment
- Would not restart after I shut it off - on to this problem...
