C101
  • NC325iC
    • Mar 2004
    • 6565
    C101
    So i took some time to search through 3 ETM's for a decent C101 Pinout and here is what i came up with, if anyone can fill in the blanks that would be great, any added knowledge would be helpful.
    Formatted as follows
    Pin#. Function - Engine side color, Body side color - basic function (notes)
    if the wire is the same color on both sides there is only 1 color listed
    1990+ 325i
    1. Charge - Bu - ?
    2. oil level - gn/yl, bu/bk - signal
    3. .
    4. coolant temp - br/vi - signal
    5. oil pres - br/gn, bk/br - signal
    6. oxy heat - gn/wt, gn/yl - +12v
    7. ignition coil - gn - +12v
    8. fuel rate (econo)- wt/bk, yl/wt - signal
    9. tach signal - bk - signal
    10. oil level - bu, vi/gn - signal
    11. inspection reset - wt/gn, wt/bu - signal
    12. check engine - gy, br/bk - signal
    13. fuel relay - gn/vi, vi/red - +12v
    14. speed - bk/wt, bu/yl - signal (from instruments to ECU from cluster C2 Pin 10 bu/yl)
    15. unloader - bk/gn - signal
    16. srs - wt/bkv -not used
    17. ABS Communication - bk/yl - signal (325ix only)
    18. starter - bk/yl - +12v
    19. .
    20. ABS power - rd/yl - +12v
    1988-89 325i
    1. Charge - Bu - ?
    3. .
    19. .
    20. .
    1987 325i
    1. Charge - Bu - ?
    2. oil level - bu/wt, bu/yl - signal
    3. .
    4. coolant temp - br/wt, br/vi - signal
    8. .
    9. .
    10. oil level - bu/yl, vi/gn - signal
    11. inspection reset - wt/bu - signal
    12. check engine - br, br/bk - signal
    13. fuel relay - gn/vi - +12v
    15. .
    17. .
    19. .
    20. .
    1986 325
    1. charge - bu - ?
    2. oil level - bu/vi, bu/yl - signal
    3. .
    6. Idle control - gn/yl - +12v
    8. .
    9. .
    10. oil level - bu/wt, vi/gn - signal
    12. .
    13. fuel relay - gn/vi, vi/rd +12
    14. .
    15. .
    16. srs - wt/bk - not used
    17. .
    19. .
    20. .
    Tach signal - C104 Pin 1
    Fuel Rate - C104 Pin 3
    Speed - Instrument cluster C3 Pin 26 br/rd?
    1985 325e (square)
    1. Charge - bu - ?
    3. .
    4. Coolant temp - br/vi - signal
    5. .
    6. Idle - gn/yl - +12v
    7. Fuel Pump - gn/vi , vi/rd - +12v
    8. Starter - bk/yl - +12v
    9. .
    10. Ignition Coil - gn - +12v
    11. .
    12. .
    13. .
    14. .
    15. Oil Level - bu/wt - signal
    16. Oil Pres - br/gn, bk/br - signal
    17. Inspection Reset - wt/bu - signal
    Tach - C104 Pin 1
    +12v means that when the car is running there will be 12v on that wire
    signal can mean a variety of things whether its grounded when the switch is activated or it puts out an actual signal
    • 34827
    1990+ 325i/ix:
    20 - rd/yl - ABS power (from main relay)
    325ix:
    17 - bk/yl - ABS communication
    M3:
    19 - Oil temperature gauge
    • NC325iC
      • Mar 2004
      • 6565
      so for the ones that arent occupied are they just empty pins?
      Im wondering where the story of the +12v to a grounded wire comes from on the motronic 1.3 swap cause i dont see an issue with me using my '89 harness on my '86 based on the ETM diagrams
      does the eta check engine signal run through the C101, cause its not shown in the ETM
      • NC325iC
        • Mar 2004
        • 6565
        I may as well include some explanation here, im wiring in an engine from an 89 into an 86. I know its been done before and i know its probably be explained but after reading x many threads where people try to explain it i still cant get the info i need, so...
        since the 86 has the C104 connector in the glove box i will not need the tach and econo signal to go through the C101 but through the C104, as this connector is in the glove box it makes the most sense to pull it from the motronic connector, so:
        Tach signal - Motronic Pin#6 (bk) connect to C104 Pin 1
        Econo signal - Motronic Pin #32 (wt/bk) connect to C104 Pin 3
          • 34827
          yes, pin 3 is never used, and 17 and 19 are only ix/M3. the+12v/ground issue is pin 20. on early cars with ABS relays it's a ground (I think), on late cars without ABS relays it's +12v. 89's have ABS relays so it's not an issue, I think it changed in 1990 or possibly 91 (wouldn't be too hard to check in the ETM).
          • NC325iC
            • Mar 2004
            • 6565
            C104 Pinout for pre 88 models
            1 - tach
            2 - +12v from OBC Relay or Main Relay
            3 - fuel
            • NC325iC
              • Mar 2004
              • 6565
              Cant find any mention of pin 20 in any of the ones ive looked at except for 1991 where it is +12v from the main relay to the ABS hydraulic unit.
              I guess ill snip it just to be safe.
                • 34827
                it would only matter for you if one of your harnesses was from a late car (I believe it's 1990 production, so 1991 MY).
                • NC325iC
                  • Mar 2004
                  • 6565
                  You sir are correct pin 20 on this harness that i have (which is unknown model year actually) is empty so nothing to see here
                  • NC325iC
                    • Mar 2004
                    • 6565
                    my 86 body side has 11 occupied pins so i guess my pinout for the 86 is correct
                    • NC325iC
                      • Mar 2004
                      • 6565
                      what does the ECU use the vehicle speed signal for? is it necessary for me to run that extra wire?
                        • 34827
                        I don't know for sure - but it's just one wire, why not hook it up?
                        E36 ECUs go into limp mode without a speed signal.. no idea how the E30 ECU is affected.
                        • NC325iC
                          • Mar 2004
                          • 6565
                          alright so here it is in short
                          Swapping in a pre '91 engine harness into an '86 with round C101 is as easy as hooking it up and making 3 connections in the glovebox.
                          1) Tach signal - Motronic Pin#6 (bk) connect to C104 Pin 1 (gn or gn/bk)
                          2) Econo signal - Motronic Pin #32 (wt/bk) connect to C104 Pin 3 (wt)
                          3) Speed signal - this one is a little more involved, run a wire from the back of the cluster connector C3 (yellow) Pin 26 (br/rd) or C6 (green) Pin 1 (bu/yl) to Motronic Pin #29 (bk/wt) for speed input to ECU
                          other than that for this specific application there should be no other problems.
                          For a 91+ harness (with C101 Pin 20 occupied) the wire for pin 20 should be clipped just to be safe, in addition to the 3 wires above
                          the only thing that i have not answered yet is the Check Engine Light which with this current wiring setup will not be functional, it will probably require running another wire from the cluster to the glovebox
                            • 34827
                            do early cars have a CEL? I guess they must, but the diagnostics is pretty rudimentary.
                            • NC325iC
                              • Mar 2004
                              • 6565
                              I donno, hadn't thought about that. It wasn't shown in the ETM even in the cluster section. Maybe I'll put in a little light in the glove box or something.
