Timing belt snapped
    • 34835
    how are people still breaking belts? it's not exactly top secret that it needs replaced every 5 years/50k.
    • StereoInstaller1
      GAS
      • 22679
      and thus my car sits.
      S50 by 2/1/2011
      Closing SOON!
      Thanks for 10 years of fun!
      • blunttech
        • 12850
        Originally posted by CabrioPunk
        I want to know Blount's pricing on these parts. I need a refresh. My buddy needs his done too.
        pm sent
        sales@blunttech.com
        www.blunttech.com
        Like us on Facebook
        • Inline Sex
          • Jul 2009
          • 346
          I knew the risk I was taking by not replacing the belt. I didn't ask "WHY DID MY BELT SNAP???"
          I asked what to do now that it has snapped, you must have misread.
          Check my feedback HERE
            • 37828
            Buy my motor, I'll swap it in too. We can work out something very fair.
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • Ceeker
              • Sep 2009
              • 2821
              slowly, manually crank the motor to check for binding. If so stop there and back it off. If not bring the motor to TDC. then turn the cam pulley to TDC. Do a compression test on each cylinder. If one or more doesn't hold then you have bent valves. Removing the head and repairing is required. You'll usually find at least 2 bent valves maybe more. If you didn't hear anything slamming or breaking then you might be lucky. but it has been my experience that even on idle valves can bent. Once you tested it then go from there.
              Resurfacing the head isn't required but since it is out for added measure it can't hurt. Remove bent valves, check the others and while you're in there remove and replace the valve seals. Check the rockers for cracks and wear on the cam shaft. See if someone has a good used rebuilt head out there- might be the cheaper alternative.
              • Inline Sex
                • Jul 2009
                • 346
                The only problem with this is that towing the car up there would probably be $300-$400 alone.
                • Inline Sex
                  • Jul 2009
                  • 346
                  Thanks Ernie, that's probably what I'll do.
                  Does anyone have any suggestions for the cheapest way to tow a car 75 miles? so far I've got $85 for an enterprise rental truck, $15 for mileage overage, $50 for a rental tow dolly and ball hitch, $30 in gas. That seems to be the cheapest way to do it that I've found.
                  • 87_black_325is
                    • 92
                    Unless you know someone that would either let you borrow a truck/trailer or tow it for you
                    87 (OO=[][]=OO) 325iS
                    Originally posted by mkcman17
                    My car is powered by hopes and dreams
                      • 34835
                      No, I understood. I just don't get why you'd take a $500-1000 risk over $35 in parts, especially if you know the consequences and can't simply claim ignorance.
                      easiest way to fix it is swap in a new motor, or swap in a new head if there's no bottom end damage. I'd pull the head and have a look, minor dings are no big deal, as long as there are no big scratches on the cylinder walls or holes in the pistons.
