Hi, simple question.. do i have to remove the camshafts in order to replace the camshaft seal and o ring? or i just need to remove the cam gear?.. any advice would be aprecciated thanks.. i know... i need to get the bentley manual again!
Question about camshaft seals
remove the cam sprocket. there are two bolts behind it, i think 13mm. this will remove the plate holding the camshaft seal. get the old one out, push the new one in. rub a little bit of oil on the inside ring of the seal and reinstall
Originally posted by ROLLingKINGi have a bronzit and plan on making it look sweet.Originally posted by slammin.e28Moral of this story?
NIce thanks dude!.. http://realoem.com/bmw/showparts.do?...10&hg=11&fg=15.. just remove number 4, and replace #8,#5.. just to make sure and get any doubts out of mi mind!no more boosted m20, 91 318i...
Originally posted by accident View Postremove the cam sprocket. there are two bolts behind it, i think 13mm. this will remove the plate holding the camshaft seal. get the old one out, push the new one in. rub a little bit of oil on the inside ring of the seal and reinstallno more boosted m20, 91 318i...
