post-valve adjustment question
  • mkcman17
    • Jul 2010
    • 8240
    did a valve adjustment yesterday, and i'm afraid that i may have done them too tight. i measured them with considerable drag to .010 on a not-completely-cold motor that had been sitting for a couple hours. am i aight? don't want to be burning any valves.
    1989 LN106 Hilux / 3.0TD SFA
    1974 2002tii / stock
    2002 IS300 / 5spd LSD
    If the head temperature was below 100F, you should be okay.
    On a race engine with known good valve guides I set the intakes to .006 and the exhausts to .008 (stone cold). I won't use clearances that tight on a higher mileage head that has worn guides, but it does give you some idea of how far you can go a still not burn exhaust valves.
    The best, and easiest/quickest, way to adjust valves is to invest in a spring tool for the eccentrics. That removes an subjective qualities from setting valve clearance. BavAuto is one source for the tool.
    • mkcman17
      • Jul 2010
      • 8240
      thanks for the info! any more you can tell me about the tool?
      • Avus E30
        • 3650
        I looked at it on pelican and it looks to me to be essentially the a spring to make the tension on the "allen" the same. with an allen on two ends of a spring.
        http://www.pelicanparts.com/cgi-bin/...ment%2C%20Each
        HDE30 <3
        • mkcman17
          • Jul 2010
          • 8240
          i see...i'm guessing we're looking at this:
          http://www.pelicanparts.com/cgi-bin/...,%20Each%20%20
          so the spring offers the proper amount of torque?
          • Avus E30
            • 3650
            thats what it appears like to me. I imagine someone may chime in to confirm
            HDE30 <3
            • lennon
              • Jun 2008
              • 1416
              you guys have got it about the tool. not too necessary but definitely makes it easier. i set them to .008 and .010 usually. if in doubt, go towards the loose side, especially on the exhaust. i would let it cool longer than that. is that .010 on both, intake or exhaust?
              • mkcman17
                • Jul 2010
                • 8240
                yeah it was cooled probably 2 hours, and the engine was definitely not 'cold.' i set them to a tight .010 at that temp. valves are pretty quiet, but i'm thinking i should re-adjust them again completely cold?
                • lennon
                  • Jun 2008
                  • 1416
                  i would. just so you know. it's not too hard to get the valve cover back off. i like to let it cool like 8 hours, overnight or something.
                    • 34839
                    I would just check it with the engine cold, you don't have to readjust everything. just make sure the exhausts aren't too tight.
                    • slammin.e28
                      שמע ישראל
                      • 12054
                      overnight
                      I've been known to get up before work and adjust them in the morning....but that's just me.
