Recommended timing belt replacement
  • actionpod
    • Dec 2010
    • 61
    Hello,
    How accurate is the recommended replacement interval? I'm buying an e30 this weekend with very reliable and complete maintenance records, showing a little less than 45,000 miles (on the belt of course, not the car). Should I replace it early or is it good for the (near) full 60? Also, it is considerably younger than the other interval mark of 4 years.
    1988 325iX
    Protection? From who, "ze Germans?"
  • StereoInstaller1
    GAS
    • 22679
    Do not fuck with timing belts. 3/36 is ideal, 4/50 is just barely.
    Head is horribly interference and will bite you in the ass if you give it cause to.
    Parts are cheap (under $100 and you are stylin'), and it is an easy 1 day job if you have any clue or skills whatsoever.
    Do it.
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
    • slammin.e28
      שמע ישראל
      • 12054
      Timing belts =
      Seriously though, I pulled an e30 out of a swamp and it had a few rockers broken and every piston had clapped a valve. Serious business, timing belts are.
      That's why I don't do M20s.
      • actionpod
        • Dec 2010
        • 61
        Do it.
        Luke
        Going with this advice, thank you for the prompt response! I'm an auto tech training so I do have access to the necessary clues and skills, not to mention a lift.
        1988 325iX
          • 37834
          If you can do it yourself it's worth the peace of mind although it will be just fine to 60k.
          Grover Beach, California
          BimmerHeads.com
          • StereoInstaller1
            GAS
            • 22679
            cam seal, cam seal carrier (if you have been working on GMs, you will fucking MARVEL at the engineering) o ring, "half moons", might as well do the TB gasket and coolant gaskets on the TB too.
            Check your alternator bushings, too.
            Closing SOON!
