improve air intake with M3 parts??
  • Pedaaa
    • Jan 2011
    • 38
    Hi guys,
    i am new here, but will start straight with some questions: ;)
    I have built a M20 2,7L conversion which runs great, but I still run it with the stock air intake system and AFM.
    I am going to replace it with a MAF, but i am not sure about the air filter and intake design.
    Then I have seen pictures of the E30 M3 intake and would like to built someting similar.
    Does anyone of you know, if this M3 carbon-intake-adapter next to the radiator will also fit, if a M20 radiator is installed??
    I also have a A/C installed, so i am using the bigger (higher) M20 radiator version.
    See attached pictures:
    My engine bay:
    M3 intake adapter for carbon air box:
  • reelizmpro
    • 9558
    Not enough room there and the diameter of that intake is like 4 to 5". You'd have to remount the radiator to the side just to fit that piece.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • matias88e30
      • Dec 2009
      • 1110
      remove a high beam, or find another way of routing it, also 19lbsa injectors and fpr along with the maf will work
      no more boosted m20, 91 318i...
