Convertible ground m20
  • richardb
    • 2121
    It's been a while since Ive had an m20, do verts have a fat ground on the passenger engine mount to the body like sedans and coupes? My car doesn't have one.... and it still runs ok.
    Transaction Feedback!
  • NC325iC
    • Mar 2004
    • 6565
    theres one on the driver side from the oilpan to the frame rail.
    The wiring harness (ECU) is grounded to the pass shock tower
    • CabrioPunk
      • 1451
      I need to get to that lower ground strap. I think mine may be frayed with some of the goofy electric stuff. Everything works just some flickering, dimming things.
        • 37833
        You should definitely fix that, ground is very important.
        Grover Beach, California
        BimmerHeads.com
        • NC325iC
          • Mar 2004
          • 6565
          i recommend adding an extra ground from the VC to the battery tray on the pass side (much like an eta ground) cant hurt to have an extra. i did this on my vert after i broke a lower ground strap and the engine shut down. luckily i rolled into a gas station just down the street from a autozone
