Well i've been have problems with overheating and air pockets for awhile now so heres what ive done so far.
water pump
timing belt
thermostat
cross-over hose
fan clutch
rad cap
v belt
completely flushed the system
and just did the head gasket with oem one and torx head bolts
SO this is where im at now unlike before i now have way better heat and now my heat works when im at a stop unlike before. At stop the temp slowly rises however if i hold the rpm at like 1200 it drops right back down to half(I have no aux fan) to me it sounds like a flow problem becaosue reving it would just help it pump more.
But this is what has me all messed up, even after driving for half an hour the bottom of the rad is still completely cold so i guess that would be because the thermostat isn't opening but wouldn't if over heat very easily if it was stuck close? I can idle for like 5 min till it gets to like 3/4 temp.
I don't think it fott he best bleed becasue after i drained the whole system and filled it with screw open and i followed everyone's instructions but i didn't get much air out but everyday when i stop driving i open the screw and get a little more air out but only a little bit.
I just don't know what to do any more and im sick of dumping money in to the same problem so does any one have any suggestions on what to do now.
Any help would be really appreciated, Thanks Stevan
water pump
timing belt
thermostat
cross-over hose
fan clutch
rad cap
v belt
