Driving along just fine to classes today the car threw up the oil pressure indicator and I knew that wasn't good. I was looking for an area to pull onto the shoulder of the highway that wasn't covered in snow and I drove it about a half mile and I heard a engine knocking whenever the car went above 2k. Thinking "shit" I just reached a cleared off shoulder and as I was pulling off the highway the CEL came on. Letting the car sit for a little, I turned the car on and the CEL/pressure lights were both off but as I reved the car to 2k again I clearly heard the knocking. I checked the oil levels just fine. No oil leaks from anywhere.
I'm thinking this is an oil delivery issue...the oil pump was installed brand new 2 summers ago after shearing off an oil pan so I'd hate to think that is the issue...but even still, the engine is CLEARLY knocking once I hit 2k. It's more of a bottom end knock, from the rod and rod bearings, not one from the valves in the top end.
I'm confused as hell, how badly could this M20 be messed up and what are my options? Rebuiling it, if that's what it came too, would far outprice the cost of finding a used M20. There is a local M20B25 that from an 87 (my car is a 90) that I could throw in and I know there are things that need to change (water pump amongst others) but he's had it sitting for 3 years in his garage (forum member "pennpenn") and isn't sure if that'd be a good idea to swap in.
So with this being my only car and I'm in classes I'm kinda in a rough place with this issue. Throw on top of that being a poor college kid. Ideas would be FANTASTIC.
Thanks.
Thanks.
