1987 325es. build date 9/86. ~210k miles.
my engine is not performing normally. but i dont think its vacuum leak or compression related. when the engine is completely cold, i can drive it for over a mile and it will act completely normal. it pulls nice and strong. after it warms up a bit (about the same time my heat starts working) the engine will stumble. if you keep a normal load on the engine, it'll start bucking. this can be stopped by either letting off the gas or giving it more gas. full gas and the car stops bucking and builds rpms, if i stay on the throttle, once i reach 2500rpm i get a huuuuge woosh of power. like a turbocharged engine suddenly reached spool and the power just takes off. sometimes, it'll even chirp 3rd when the power kicks in.
im really confused, and im tired of throwing parts at it.
i have replaced or inspected:
cap and rotor. (new)
spark plug wires. (new)
spark plugs. (new)
1 eta trans sensor. (new)
injectors are good. (all orange pintle caps are nice and shiny from gas exploding)
3.0 FPR from an i. (this actually helped quite a bit, made it from undrivable to barely livable)
adjusted the valves.
dme temp sensor. (new)
if its a vacuum leak, it would be inconsistent when it runs. if its compression, it would run better when hot. but nope. it runs great when cold. it does burn a decent bit of oil.
it used to stumble a bit, but then when i got on the highway it would clear up and act normally. now its all the time after it warms up. the FPR really changed how it acted, so i want to say its fuel related and not.. say a bad dme. but maybe it is. it has a 153 iirc.
im really lost here. its getting 25mpg and i commute 70 miles a day back and forth to work, so not getting 30mpg really hurts at the end of the week.
spark plugs. (new)
