Stupid questions.Pilot bearing, Plug wires
  • TimKninja
    • 2131
    Rebuilding my B27, Also doing 5 Speed swap. Now I see pelican parts has a cover and a felt ring for the pilot bearing. Are these parts needed ? or are they just for the non sealed bearings?
    Also what would R3v recommend for Plug wires, looked around, everyone says bosch. But the Honda fags say NGK makes better wires at a fraction of the cost. theres a NIB set for $65 on ebay.
    1985 325e M50TU(Sold)
    1991 318is Slicktop (Sold)
    1990 325is Brilliantrot S50/5 Lug Swapped.
    1992 525i Manual shitbox Winter Beater
    • 37834
    They are for non sealed bearings. I always buy a sealed bearing.
    For the wires, Ireland Engineering sells 8mm wires for $85.
    Grover Beach, California
    BimmerHeads.com
    • NC325iC
      • Mar 2004
      • 6565
      or you can contact one of the forum sponsors for a nice set of stockers. the bremi wires are really good quality and you wont notice a difference with 8mm. Im sure blunt or guten can get you a good deal, maybe even better than ebay.
      (i woulda thought a mod would push that...)
      jk matt
        • 37834
        jk matt
        Well, most people go for the aftermarket since it's cheaper than an OEM equivalent replacement a lot of times.
        BimmerHeads.com
          • 34847
          the NGK wires are probably fine. Bremi are pretty nice too.
          if it were me, i'd buy a $50 plug wire kit and make my own.
          • NC325iC
            • Mar 2004
            • 6565
            dont you need wires with a resistor in line or something like that?
              • 34847
              I don't think so. You can use resistor plugs anyway.
              like NGK BPR5ES :)
