Coolant light keeps coming on
  • NO SHAM3
    • Dec 2010
    • 28
    My coolant light turns on after driving a couple minutes. The coolant level is good and the car does not overheat. Coolant temp doesn't even reach the half way mark. My only guess is the thermostat stuck open, but not sure. Has anyone ever had this problem?
    • 37828
    The coolant light has nothing to do with the thermostat...
    It's attached to a level sender on the expansion tank. They fail all the time.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • StereoInstaller1
      GAS
      • 22679
      He forgot to tell you to replace the sensor
      Closing SOON!
      Thanks for 10 years of fun!
      • E30Gus
        • Jun 2008
        • 781
        While you're under there..........Smoke test!
        • Ceeker
          • Sep 2009
          • 2821
          change your coolant level sensor; the light should go out. common problem as noted above.
            • 37828
            I never usually get to that step, haha!
            Grover Beach, CA
            www.BimmerHeads.com
            • NO SHAM3
              • Dec 2010
              • 28
              Thanks guys. I'll replace that this weekend
              • RONZEASy
                • 24
                I have the same problem only my coolant sensor isnt connected to the harness... Having trouble locating the plugs can someone help please :)
                __________________
                Be Free
                RONZ
                • dnguyen1963
                  • Nov 2011
                  • 2648
                  remove the sensor and clean it. You do not need to buy a new one. There is normally a lot of buid-up on the electrode preventing the electrons from moving...similar to low coolant level.
