eta motor
  • Pat W
    • May 2004
    • 321
    eta motor
    would it practical to start a stroker motor with a eta or be eaiser to start with the m20b25?..
    JDM no more
    • 34839
    B25, swapping cranks is easy but there is no magical way to change an e head and intake into an i head and intake. ;)
    • Pat W
      • May 2004
      • 321
      yes but i thought that by using the e bottom end and the i head and what not you would basically have a 2.7i....now i know you need to run custom pistons or super eta pistons....
      but this would be ideal because im planing on turboing it after stroking it....
      comments
      JDM no more
      • Madhatter
        • Oct 2004
        • 966
        you dont really need to swap blocks though, like nando said, all you need to swap is the crank and rods / pistons (or go custom, or super eta, or whatever).
        Both the eta and 325i blocks have the same bore size, the difference is the eta crank has a longer stroke.
        Just a little project im working on
        - http://www.lse30.com -
          • 34839
          comments
          no, because just bolting the i head on an e block gives you very low compression. you have to rebuild the bottom end anyway (with pistons made for the new bore/stroke), so just start with a B25 and find an e crank somewhere. much cheaper than finding an i head and intake.
          the alternative "easy" way is to start with an 88 eta and changing it to an i cam etc. but you're stuck with 8.5:1 compression..
          • EverWiser
            • Aug 2004
            • 313
            comments
            An i head on an eta bottom end will yield a CR of close to 8:1; I've heard some say 7.9:1. If you're planning to turbo it you would be in very good shape with that CR. As far as 8:1 being "too" low, not really. Although you won't put out as much total HP with a lower CR you will be able to run more ignition timing without detonation; especially on the pump gas that most of us can buy...Just my .02.
