The Loud M20 Valve Train
  • craiggroves91
    • Oct 2009
    • 3024
    I've been wondering is it possible to get rid of the famous loud m20 valve train ticking?!
    I know a valve adjustment can help.
    I was thinking there is no way these cars sounded like that new
    or did they?!
    I would trip if I saw an m20 running without hearing that ticking.
    It would be nice!
    Please show me one.
    I always thought a running m20 is a ticking m20.
    1989 BMW 325i SOLD
    1998 BMW Estoril Blue e36 M3/4/5 SOLD
    1987 BMW 325 (The Piece) SOLD
    1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
  • lolcantturn
    • 4588
    a ticking M20 is a happy M20 yes.
    be proud, it's clapping at you.
    But to answer your question, no you can't get rid of it, but thicker oil certainly helps. In addition to a nice valve adjustment, thicker oil made my M20 sound much healthier.
    Originally posted by TSI
    OEM+
    • craiggroves91
      • Oct 2009
      • 3024
      Yeah I'm gonna do a valve adjustment ASAP
      Im using 20w50 oil.
      I've just been so curious how they sounded new.
      1989 BMW 325i SOLD
      • matias88e30
        • Dec 2009
        • 1110
        Valve adjustment its a must in maintenance for the m20....
        no more boosted m20, 91 318i...
        • travisn
          • 19
          I've heard it's the injectors(?)
          • LowR3V'in
            • 4209
            On m30s, most measure at the cam because the eccentric wears a groove in the valve over time.
            Not sure if the m20 is physically big enough to get a feeler in there though.
            My m30 has 0 click after doing it this way.
            Only thing I hear clicking is injectors.
            • Airplanecar8
              • Jul 2010
              • 64
              I dont think thats true.
              with the right valve train our engines could sound pretty quiet. beehives anyone?
              • browntown
                • Jun 2004
                • 3524
                I have a blown headgasket, but not much valve tick at all.
                  Noise from the valve train when the valves are correctly adjusted is usually a sign of worn valve guides. A bit of ticking from the valves when the engine is cold is normal, but if the head is in good condition and the valves properly adjusted that noise should go away once the engine warms up. The valves on an M20 or M30 engine should be adjusted every 15k.
                  Injectors can tick also and sound like valves. An automotive stethoscope will quickly tell if the ticking is from the injectors.
                  • imdashiz
                    • Sep 2009
                    • 1373
                    The injectors are actually pretty loud and most likely what you are hearing. The valves stop ticking as much when the car is warmed up.
                    PSN ID: Yourself1
                      • 34847
                      agreed. it shouldn't really be loud. At idle you can't really hear my valves at all. I think most people just have worn engines.
                      • Blendercloud
                        • Jan 2011
                        • 236
                        I've just been wondering this myself. I just adjusted the valves on Friday and the car is loud as hell under load. Less of a valve tick and more of a valve rumble. I've begun wondering if I might be do for some rocker arms. Though if I do rocker arms I might as well rebuild the whole damned head.
                        I think I'll try stepping up to a thicker oil first. What oil do you guys run in your M20's?
                        Chris
                        '83 320i - Crashed :(
                        '71 Nova - (9.71 @ 172mph) - Sold
                        '83 320i - Taking Offers
                        '01 325i - Sold
                        '07 Mazdaspeed6 - Sold
                        '89 325iX - Rust Free, 2 Door, 5 Speed
                        '06 M5 - Interlagos Blue SMG
                        • Stanley Rockefeller
                          • 445
                          Castrol Hypuron 15w40 semi syn diesel oil...cheaper than full syn, and keeps my motor quiet!
                            Valve noise is hardly ever load sensitive. But a bad bearing is load sensitive. Have a pro check out the car see what he/she thinks the source of the noise is.
                            • MTechnikII
                              • Jun 2007
                              • 83
                              how loud is loud? the M20 engine is no way as quiet as a TOYOTA engine, I was told once by a BMW mechanic that the M20 valves should be adjusted to be a bit nioisy, quiet engine does not have correct valve adjustment.
                              and valve adjustment is critical for MPG.
                              Henry
                              Also heavyer oil makes the engine more quiet
                              I use 10w30 mobil 1 and it's noisy when I use 20w50 it becoms more quiet
