5 Speed swap
  • Predzy743
    • 644
    5 Speed swap
    What all would I need to do a 5speed swap to my 325is
    I started with the idea of doing an eta setup so this is what I currently have.
    Eta trans G260
    early model shifter rebuild
    eta clutch (is there a difference?)
    eta TOB and pilot bearing
    eta driveshafts
    What would I need to do it the proper way with I parts? Can I keep anything I currently have?
    Thanks
    -Steve
    88 Zinno M3
  • StereoInstaller1
    GAS
    • 22679
    Clutch master/slave, pedal set, and you have to have the proper flywheel: you want early ETA that has the position sensor. You might wanna shave a couple pounds off it, and of course a new pilot bearing.
    Closing SOON!
    Thanks for 10 years of fun!
    • Predzy743
      • 644
      Well I dont want to go the eta route anymore. I just have all that and then changed my mind.
      I want the I trans setup.
      I have the pedal box as well, master and slave. and I also have a 323i euro flywheel.
      My real question is. Can I use the eta clutch and driveshafts as well as the pedal box? I heard something about pedal boxes being different between the airbag cars and the non. I did a non airbag swap I dont know if that helps.
      Thanks
      88 Zinno M3
      • StereoInstaller1
        GAS
        • 22679
        If you want to use non-airbag pedals on an airbag car, you have to do the whole box as I understand it. What I do know for sure is you don't have to change the box on a non-bag car.
        Closing SOON!
        • Predzy743
          • 644
          Ok cool.
          Will an eta clutch work in a I trans?
          88 Zinno M3
          • i<3e30325s
            • 10
            http://www.e30mk1.com/Other/5spd%20swap/ hope this helps
            • Predzy743
              • 644
              Awesome thanks. That helps with install. Just need to know 2 more things yet
              88 Zinno M3
                • 34839
                I think you can just swap the pedals. or at least, that's what you want to do - removing the airbag pedal box is not easy, and it also supports the steering column. I don't remember if the airbag/non airbag pedals are the same, but the boxes definitely aren't.
                • Predzy743
                  • 644
                  What the difference between the box and the pedals? I took the whole pedal assy out of the non airbag car. is that what you mean by pedal box?
                  88 Zinno M3
