I got Milk.
  • pwagon717
    • Jun 2007
    • 1197
    I got Milk.
    On the new freshly new rebuilt head. Rocker broke. Only got 60 miles on this motor since rebuild.
    _________
    Rep Savannah Crew
    • 34844
    I think you have more problems than a broken rocker. looks like you have a LOT of water in your oil, and possibly a gigantic vac leak for it to get that far down the intake. the broken rocker is likely a symptom and not a cause.
      Drain the oil and see if it has milkshake. I'm guessing that it will, which would mean that the headgasket didn't seal or that the head is cracked.
      • pwagon717
        • Jun 2007
        • 1197
        That was the first thing I did, it was the milk. It is crazy that it is cracked, because the head was pressured checked and decked. Seals changed in the head, and everything.
        _________
        Rep Savannah Crew
        • Jaxx_
          • Dec 2009
          • 1880
          magnafluxed?
          • thereisnoyun
            • Feb 2007
            • 2301
            I would vote for timing was off, valve impact, that dmg either hte head seal, or crack the head, and broke the rocker in the process. I think broken rocker is the result definitely not the cause.
            • pwagon717
              • Jun 2007
              • 1197
              Double checked the timing, also had two others check the timing. Got to rule that out. But I understand where you coming from.
              _________
              Rep Savannah Crew
