Can you use M50 injectors (i think they're 17lbs) in the m20 motor for a 325i if you're using a markD chip?
E36 injectors into an m20?
Tags: None
The chip will allow for more power since it will make the fuel and timing maps more aggressive. The larger injectors are not necessary from what I understand (unless you have extensive modifications like a stroker kit and large cam but even then I am not entirely sure where the line is drawn on when you need larger injectors). The benefit of the M50 injectors is that they are a 4 pintle design which is supposed to provide better fuel atomization. I would guess that rebuilt/cleaned M20 injectors would allow for more power than any old junkyard M50 ones though. To me the priority is good clean injectors and not so much injector size.Comment
