I don't like Bosch
Haven't sucked a shopping bag into the airbox have you?
Possibly full of dog food?
Rotor possibly look like the bottom one in the image below?
^ Damn how in the heck did that rotor get like that? I will be checking the cap and rotor soon. I'm kinda busy. I'm a single parent, so I don't have as much time as I would like all the time.
@Dough-I don't have a Bentley manual. I do have a Haynes. I will look again to see if it has an electrical systems test. I don't really think that it does.'02 Outback wagon
'87 325is 5sp
'93 Kawasaki ZR1100Comment
Ok I made an inline fuel press. gauge. When I start the car up and let it idle, it reads just below 40 psi. I don't know if I should say that is good or not. It is below what my Hanyes book says it should be.(43-45psi at idle) I have to get a longer piece of hose so I can see what it runs while I'm driving.'02 Outback wagon
'87 325is 5sp
The coil is prob. factory. I have not checked the plugs in a while, but the last time I did they were fine.
I just checked the cap and rotor. They both look good.(like new) I just put another new fuel filter on. I'm goin to pull the injectors soon, and check them out. IDK what else to check. HELP ME!'02 Outback wagon
'87 325is 5sp
no problem john. are you going to try another set of stock injectors, or others?
an OE replacement coil locally is gonna run around $80 iirc.
hopefully the injectors or coil will help your problem. just don't mix up the feed and return lines when ya put it back together. if it doesnt, maybe you could bring it by here and i can check it out. i don't know the most about these cars, but heh, another opinion couldn't hurt. just don't take it back to wulff's, save your money :PComment
Ok I did some more test. I checked the ign. coil. The primary side is a lil high at .8 ohms., and the secondary side is on the high side as well at 6,000ohms. when warm. I may need to change that?
The next thing I did was check fuel press. while driving. At idle and just norm. driving, it has good press. But when I try and give it some gas the press. falls right off to near 0 psi. So does that mean I need a fuel pump?'02 Outback wagon
'87 325is 5sp
If the ignition coil is testing outside of spec you should replace it. Have you checked to see what the spark looks like at the plug to see if it is strong?Originally posted by DozyproductionsYou know why you're drinking that Pabst? No its probably not because it was the first beer you grabbed. It's because you're a winner.Comment
