have you ever tried....
  • KillaCam
    • 2103
    hooking your oil cool lines into the trans cooler part on a automatic radiator....would that work? besides the possible different fitting size.
    would there be any benefit from doing that?
    Originally posted by E30_(1st Musk)_
    HONDA IS WHERE EVERY TREND DIES! .
    24v swap Oil Pan..F/S
  • SpecM
    • Oct 2005
    • 4531
    I don't see the benifit
    the OE oil cool seems like a more effectiant heat exchanger
    1989 cirrisblau-metallic 325i
      • 37829
      Well it could work yes, since it would do the same thing. The separate OEM oil cooler would definitely be better though.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • SilentJon
        • Feb 2011
        • 88
        the auto trans cooler doesn't cool as well. you have to take into consideration that it's integrated into the radiator, so whatever is flowing thru the trans cooler portion isn't going to get much cooler than the coolant
        • xwill112x
          • Jan 2009
          • 4236
          The fluid is made to operate at that temp as long as it isn't over heating.
          • KillaCam
            • 2103
            thanx for the info!
            not gonna do it then.
