89 325is new head gasket, wont start
  • Krueger
    • Feb 2011
    • 124
    Hey everyone i just got finished putting everything back together and now the car wont start, any suggestions, i have spark,timing appears to be correct now ticking pinging or anything. Cheers
  • Dj Buttchug
    • Jun 2010
    • 7688
    fuel?
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • ttrousdell
      • Nov 2009
      • 1770
      Its probably something simple. Id make sure the fuel lines werent switched.
      The Build:
      • sweet6e30
        • Feb 2011
        • 531
        ground strap on oil pan drivers side?
        fuel lines switched ?
        crank impulse sender ?
        all sensors plugged?
        my build here ---> http://www.r3vlimited.com/board/show...ht=lemans+blue
        • Krueger
          • Feb 2011
          • 124
          I havnt messed with the ground strap but there is no protective covering on it, i dont know if that makes a difference, i check the book and im sure i have them right, the line coming from the fuel filter goes to the fuel rail and the line coming from the tank connects to the fpr,
            If this is a 325 built after 8/87, check C191 under the intake manifold.
            • ttrousdell
              • Nov 2009
              • 1770
              ^correct me if im wrong but if there is spark doesnt that mean that the cps is working and if the ground strap is not connected then the starter wont even work because its grouned through the engine. Also from my own experiences, the car should start as long as that small round connection under the intake (c191) that supples juice to injectors is pluged in, cps and spark wire sensors are connected. yes the line from the filter goes to the rail
              The Build:
              • Krueger
                • Feb 2011
                • 124
                Everything is connected, with timing does it matter on which stroke you line the cam-crank up?
                • Krueger
                  • Feb 2011
                  • 124
                  Or as long as they are lined up?
                  • Krueger
                    • Feb 2011
                    • 124
                    Hey ttrousdell is ur motor out of an e24?
                      As long as the timing belt is installed with the crank and cam sprocket marks lined up, the engine will be in time.
                      • ttrousdell
                        • Nov 2009
                        • 1770
                        it was out of a e32 1992 735i
                        The Build:
                        • Krueger
                          • Feb 2011
                          • 124
                          So i have no fuel going to fuel rail wtf?
                          • ttrousdell
                            • Nov 2009
                            • 1770
                            do you have 12V at fuse #11.
                            The Build:
                            • Krueger
                              • Feb 2011
                              • 124
                              No 7.5, brown
