SETA Pistons
  • Andy348
    • Sep 2009
    • 688
    SETA Pistons
    I know I'm going to get flamed for this, but I've searched for three hours now and can't come up with a 100% definitive answer. I'm 90% sure this is correct, but I'll ask anyways.
    I can use an 86 eta bottom end, SETA pistons, 885 head w/all I electronics, accessories and wiring to make a '327i' and end up with a CR of 8:5:1?
    Thanks.
    • 37834
    Yes, you are correct! Super Eta engines use the same crank and rods as a regular Eta engine.
    Grover Beach, California
    BimmerHeads.com
    • CorvallisBMW
      Long Schlong Longhammer
      • 13039
      Not to threadjack, but...
      Changing to 'i' rods ups the CR to, what 9.5:1? Anyone know of the power difference between the 2 options?
        • 34847
        That doesnt work, the pistons would protrude 5mm too far. So your cr would be approx 9999:1 ;)
        • CorvallisBMW
          • 13039
          Good to know lol
          • KenC
            King of Kegstands
            • 14396
            What about stock eta crank, eta rods, euro eta pistons, with 885 head?
            Originally posted by Gruelius
            • der affe
              Technical
              • Dec 2005
              • 8452
              The 885 head will drop the pistons compression ratio down by 1 point. IE, 10.5:1 will become 9.5:1. At least that is what I figured out win my euro eta pistons.
              • CorvallisBMW
                • 13039
                hmmm, so if euro eta motors were 11:1 then an 885 head would result in 10:1... perfect :twisted:
                • der affe
                  Technical
                  • Dec 2005
                  • 8452
                  The squish of the piston is a bit of a mismatch for the 885 head, there have been some discussions about it and where the down fall lies or how much HP may actually be lost because of this. I have never seen anything concrete as far as an answer though.
                  Good luck finding early eta euro pistons in decent shape anymore though. It took me a while to find mine.
