Shaky Warm-up
  • llll1l1ll
    • 782
    Shaky Warm-up
    Hey all,
    '88 325is here.
    My car shakes a lot while warming up. Only at idle though. I went through and sealed the vacuum leaks that I found using a hose and listening for hisses. Car is still shaky idling - particularly during warm-up.
    Would this be my coolant temp sensor for the fuel injection? Would replacing that require me to drain the coolant?
    For the record I just replaced the spark plugs and the distributor cap and rotor are fine.
    Thanks,
    Peter
    Me: "I can't wait to redline my car!"
    Mark: "Didn't you just break a rocker arm?"
    Me: "Yeah, I don't think I've learned my lesson."
    Mark: "You never will."
    • 34844
    it could be running a bit lean. you don't need to drain any coolant to change the CTS, but a little might spill out. it's not an expensive part so it's worth a try. I'd also consider measuring the resistance of the CTS wires back to the ECU.
      While the ECT (aka CTS) sensor is a possibility, I'll bet that you haven't found all of the intake leaks. Have a shop run a smoke test on the intake.
      • llll1l1ll
        • 782
        Hey guys sorry for the late response. Anyway I'll try to see if I can get a cheap-o coolant sensor while I search for a good shop to get a smoke test done.
        Thanks!
