headgasket question
  • Killacortes
    • 1937
    headgasket question
    i just put a new head on 89 ix and realized its leaking water on the new head gasket i just put on. so im guessing i fucked up torquing it down right. Can i get away with just new head bolts or do i have to get a new head gasket as well? never fired the car up or anything.
    r3v does not fuck around. First you get banned, then they shoot you
    If this was a new, as in brand new, part I'd suspect that the gasket got damaged. But I suspect that this is a used head and that you didn't have it checked for warp or cracks before installation. Either way the head has to come back off and a new gasket and bolts used and the head needs to go to a machine shop.
    That assumes that the leak is between the head and the block. This could be a leak at the thermostat housing, water pump, or heater port.
    • Killacortes
      • 1937
      head was resurfaced and there's nothing wrong with the gasket. can i re use the head gasket and just get new head bolts?
      • StereoInstaller1
        GAS
        • 22679
        How did you torque it?
        Closing SOON!
        Thanks for 10 years of fun!
        • Killacortes
          • 1937
          just how the instructions said 30nm, 90 degree turns x2. but then i took the head back off and used the same bolts. i just dont want to have to take the head off again. should i just take it off along with a new gasket and new bolts?
          • Liam
            • 753
            You did what?
            No.
            I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃xS : φ(x)) → (∀xS : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
              • 37828
              Wait it's leaking but you never ran it?
              You reused the bolts after already torquing them?
              Buy a new gasket, buy new bolts.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • Killacortes
                • 1937
                fuck! yea i messed up when i was putting it on and had to take it off. what about the tensioner its brand new. i read once its tensioned you cant reuse them? so should i get a new tensioner as well
                  When installing a head a wise mechanic will only run the bolts up to initial torque (22ft-lb) and wait to angle torque the bolts until everything else has been done. That way if you discover that the head has to come back off the gasket and bolts can be re-used.
                    • 34839
                    you can retension the belt just fine
                    you can't retorque the bolts though. you need new bolts and a gasket.
                    I just went to an AISC bolting seminar - it turns out, angle turning bolts are very forgiving. basically you can't really mess it up if you do the 22ft/lbs-90*-90*, even if you just eyeball the angle. +/- 10 degrees isn't going to make a lot of difference. it's leaking because you reused TTY bolts.
                    • StereoInstaller1
                      GAS
                      • 22679
                      Serious? What a relief! That matches what I have always thought, but I bought a gauge anyway...
                      Closing SOON!
                        • 34839
                        yeah. If it's good enough for skyscrapers and multi-billion dollar bridges, it's good enough for a $500 m20.
                        the only thing you can potentially screw up would be dirty threads or using the wrong sequence.
                        • z31maniac
                          • 17566
                          Good reminder, tap size needed?
                          www.gutenparts.com
                            • 34839
                            12x1.5 I think? I don't realy know, lol. I always used Q tips :weak:
                            • Jargo
                              • 490
                              Agreed, awesome info there! Always wondered about that myself.
                              Owned lots of E30's
                              Currently sporting:
                              85 324td
                              86 535i
                              89 635csi
                              Feedback thread
