I recently went to change my oil, Everything went as planned until I left and was driving home when my check light came on and I immediately notice the engine oil light came on my overhead. I pulled over and check it out and the stick read 1 qt. When I completed my oil change before all this happened I looked under the car to see if any oil was leaking I found none. When I started my car there was no smoke or anything unusual coming out of my exhaust. There is no oil in the coolant. I dont know where it is all going. I lost 3.5 qt in a matter of an hr. I dont know what else to check for. Please help thanks
Oil dissapearing
The stick reads 1 qt? Maybe I missed the memo but I have never heard of a mark on the dipstick saying that there is only 1 qt of oil left. I have heard some people say that on some cars, the difference between the max. and min. mark on a dipstick is 1 qt. which may be what you are refering to however I don't take this to be fact. ( please inform me if I am wrong though, I am here to learn as well). During my last oil change, I filled it up with the capacity stated in the Bently manual. Started it up, and the check panel "Oil Level" light was on. Strange. I ended up adding nearly a quart more than the Bently suggests for an oil change just to get it to the correct level. For my situation, my theory is that I let the car sit all winter and hadn't started it. So all the oil from the head and other parts had a chance to drip down to the pan and more oil drained than usual.
I do not have any leaks either and I had to add an extra quart to be at the right level so I know where you are coming from to some extent.
also
I don't know about e30s specifically. but I know on some other cars I've done, when you first start it up right after changing the oil it will seem to "lose" some oil, but it's really just moved from the oil pan to the heads an oil filter.
My practice is to start a car up after finishing an oil/filter change and let it run for a minute, then re-top it off.
The oil sensor light came on. I have checked it hot and cold and still cannot find where all my oil went. There is no oil on the ground where I did my oil change and I did not see any leaking anywhere. Where could it have gone?Its not a qt low. I put the recommended 4.5 qts in it and drove a dew miles back to my house and the light came on. I pulled over and checked it to find most of my oil was gone. The bottom of the dipstick and a small amount of fresh oil and that was it.sigpic
