m20 stroker stumbles and quits (long, help)
  • NC325iC
    • Mar 2004
    • 6565
    First background on the engine.
    has been running in my coupe for a couple weeks now
    stock i exhaust barring stromung muffler
    stock i intake manifold and throttle
    Miller PSIK and war chip with tune
    Last week being about the first time id really got to drive it i put it through about 30-40 miles of test runs just cruising with a little spurt of speed every now and then. It was running magnificently, absolutely amazing (ask n2mye30). Put it away for the week as my commute doesnt warrant the power. took it out friday evening for about a 20 mile drive just wandering around for fun, was running quite well, a little stumble here and there on my way back home. Made note of it and contacted brody with the issues as he asked me to, thinking it might be a little thing in the low throttle range of the tune. Yesterday didnt get much driving in, just a quick run around with my dad to show him how it was going, no issues very short drive. Today i take it out head up to my uncles place to watch the LFC-AFC game with him, running fine on the way there (with the now known stumble at low revs and low throttle) runs fine at the half when we go get food. Leave his place after the game and head to my dads place, running fine still with the occasional stumble at low throttle, but still not significant enough to be worrisome. Im at dads for about 10 minutes then im heading out towards school, get on the highway to head out there and it starting to hesitate a bit. I see on my AFR gauge huge swings from way lean to way rich and i back off down to about 50mph. after about a mile it stabalizes and i get enough courage to get back up to cruising speed. So im at the Wolfpack Motorsports shop checking out the weekends progress on the Baja SAE car. Im there for about 10min and i take off back towards home, on my way back to the highway im getting some hesitation similar to what was on the highway so i back off and try to hold fairly constant rpm. I approach a stop light push in the clutch and it slow dies out, im watching the afr and it is fully lean. I manage to get it started and into a parking lot where it again dies out. After letting it sit for about 15-20 min i decided to give it another chance fired it up, now i can keep an eye on both AFR and manifold vac, at first it fires up just fine vac jumps to ~15in (where it is when idling normally) afr is a fairly calm. Then after about a sec of idling alright the vac starts to drop off gradually and AFR leans out and engine dies.
    Things i tried in the lot:
    re seat many connections
    unhook o2 from computer (results in much worse idling for that 1 sec)
    unhook ecu to reset
    nothing had any effect, so i got a tow home
    I did a quick google on vac gauge reading which suggests this reading to be a clogged exhaust. This would fit as i bought the cat from a junked car, who knows how bad it is. I want to know though a) if this fits with the AFR readings b) if there are any other likely scenarios.
    For me best case is clogged exhaust as that can be easily fixed, what else is it likely to be (keep in mind that it was running strong recently with no indication of any major problems until todays events) almost everything is new within the past 80 or so miles (on the engine)\
    thanks
  • NC325iC
    • Mar 2004
    • 6565
    Nando? Jlevie? Anyone?
    The more I think on it, it makes sense. If the exh gasses backed up into the cylinder enough that air was not being pulled past the maf (which is indicated by dropping vac) then the fuel would gradually be cut, which would lean and kill the motor.
      • 34839
      a clogged cat shouldn't affect the AFRs. it will get very hot and probably smell though. if you had a test pipe it would be easy to check.
      To me it sounds electrical. How old is your fuel pump relay? did you ever try it with the stock computer/AFM?
      • e30rapidic
        • 2167
        what exhaust do you have? I have a complete M20 system in the garage, sans manifolds that you can test out. I'll need it back pretty quickly though.
        '87 325ic, powered by S50.
        • CorvallisBMW
          Long Schlong Longhammer
          • 13039
          How about your fuel system? FPR? Clogged filter? Failing pump?
          • NC325iC
            • Mar 2004
            • 6565
            The relays are not brand new. Neither is the pump. The for and filter are both new. I will crank it up and check the fuel pres gauge, but it seemed to still be holding ~36psi after shutoff. I didn't run it on a stock computer, and can't do so without changing harnesses or undoing some wiring id rather not undo. I have an open downpipe I can try out later this week.
            Also I was getting a plasticish smell that I attributed to the new muffler, could that be the cat?
              • 34839
              cats will usually smell like rotten eggs
              since the relays are original I'd replace them anyway. I chased a problem for almost 2 years that turned out to be a bad main relay. It wasn't until it got really bad that I figured it out.
              • mattdk318i
                • Jun 2006
                • 3953
                This, i had the same problem with a fuel pump relay. Tested it and tested it. The contacts would release intermittantly making it stall like a misfire..
                  • 34839
                  yeah, I was getting ECU resets. Well, what I thought were resets.. it was really the ECU shutting off from the bad relay. Felt like a rev limiter.
                  • N2MYE30
                    • Oct 2007
                    • 5536
                    There is a lot of good info here but let me just say that when this car is working at 100%, this M20 was moving! Very impressive.
                    COTM
                    • billybobjoseph
                      • 213
                      That is one sharp car N2MYE30
                      • NC325iC
                        • Mar 2004
                        • 6565
                        Fired it up today with the hood up to keep an eye on the fpr. It fired right up and idled for about 5 min never a waiver in the fuel pres. No sooner than I close the hood and sit down to go for a spin than it starts to sputter, pop the hood quick to see the gauge and its rock steady. I'm gonna try the open exhaust this weekend, or I'll try to replicate the issue on my other e30 by plugging exhaust.
                        I did hear some faint rattling in the cat area, whether it was actually from the cat or not is unknown.
                        • NC325iC
                          • Mar 2004
                          • 6565
                          ruled out relays, swapped them coupe-convertible and vice verse, convertible ran fine coupe still died the same way after it idled and revved just fine for a while.
                          I also ruled out that it was my electric fan sucking all the power away from the engine (when the fan kicks on the engine takes a little stumble but recovers normally) i unhooked it just to check.
                          Anyhow it still does the same thing, it runs perfectly for a few minutes (temp needle got out of the blue) and then kinda out of nowhere it just wheezes and dies.
                          will test exhaust next... any more suggestions?
                          • billybobjoseph
                            • 213
                            Is it always after the vehicle warms up, and does it run just fine while the temp is in the blue?
                            • iX-treame
                              • 440
                              ^^^My coolant temp sensor was toast and made my AFR go wack so test that out.
                              '88 325iX -Totaled
                              '97 M3 - Sold
                              '85 euro e30 Pete McHenry 2.8L m20 Stroker - Parting out
                              '89 325is - Sold
                              '95 540i 6spd
                              '87 325is M Technic I s50
