Are the IM shaft bearings replaceable?
  • Cinnabar325is
    • 1064
    Common sense would say that they are. However, I can't seem to find new ones anywhere. Searching through the archives here led me to a post by one knowledgeable person who said they aren't and another who said they are.
    What gives?
    My bearings have some checking on the surface and the outer bearing is even chipped on the edge.
    Thanks.
    '89 BMW 325is Zinnoberrot / '88 VW Jetta GLI 16v Tornado Red / '89 VW Jetta GLI 16v Tornado Red / '89 VW GTI 16v Bright Blue Metallic / '91 BMW 325i Black / '91 BMW 325i Sport Black / '92 VW GTI 16v Black / '92 VW GTI 16v Montana Green / '01 Audi A4 Avant TQM Silver Metallic / '01 VW Jetta GLX VR6 Black
  • whodwho
    • Jun 2008
    • 1547
    They are available and need to be sized/reamed
    11 11 1 280 863
    11 11 1 264 196
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • riceh8r
      • Dec 2010
      • 133
      yes, and will require a machine shop. this is not a diy project.
        Correct!
        Although listed as NLA, the bearings are availble if order by part number. The part numbers are:
        11-11-1-280-863
        11-11-1-264-196
        Measure the IM shaft diameter, chuck the bearings up in a lathe, slow speed,
        cut to initial size. Use a standard cam bearing installation tool and install
        them in the block, they will crush and become smaller then the diameter of the
        shaft. Hand finish with a brake cylinder hone, low speed and a little goes a
        long ways. Test fit, finish sizing with green scotch brite. Oh ya, make sure
        the front bearing lines up with the oil feed hole from the #1 main bearing
        feed (The second bearing does not matter as it is fed through the shaft from
        the front journal)
        You want about .0001-.00015" clearance, I would say .0002" max.
        • SpecM
          • Oct 2005
          • 4531
          ^ sheesh Jim, you make it sound like its as easy as adjusting valves
          1989 cirrisblau-metallic 325i
          • Cinnabar325is
            • 1064
            Great info, thanks guys. Anyone know for sure if they're available some place other than the dealership?
              • 34839
              anywhere that can order BMW part #s can get them. For example: blunttech.com
