lower seals
  • Harry's E30
    • 643
    lower seals
    hey, so im failing at replacing the crankshaft seal any tips on removing the crankshaft thanks in advance.
    BUILD-http://www.r3vlimited.com/board/showthread.php?t=242728
  • Jargo
    • 490
    Engine in car or out?
    If its out of the car here's how I did it...
    Install an old vibration damper that doesn't matter if it gets boogered up. Wrap a big old chain wrench around it connected to a 6 foot bar. Then get another 6 foot bar for your 22mm crank nut. Get the one bar wedged against the ground, wall, or anything else to hold the weight. Then hang on the other bar with all you got till that big old bolt breaks loose!
    I've also heard of jamming the crank with a bar, although not sure I'd recommend that. Probably other ways as well, have to get creative to break 300ft/lbs!
    Owned lots of E30's
    Currently sporting:
    85 324td
    86 535i
    89 635csi
    Feedback thread
    • Harry's E30
      • 643
      The engine is in the car and i have a piece of wood enabling the crank to rotate which surprisingly holds i just dont seem to have enough strength to break the crank loose but thanks anyways all try and get creative.
        • 37828
        Wait, removing the crank?
        Stop.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • Harry's E30
          • 643
          yes the crank
          • Myster-E
            Performance
            • 552
            You must be high. you don't need to remove the crank to replace the seal.
            1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
            Visit www.BimmerHeads.com for all of your 12 valve needs!
            • Harry's E30
              • 643
              please then inform a noob on what needs to be done i have replaced the camshaft seal but dont know how to get to the other 2 seals
                For the front seals, you have to remove the crank hub and then the lower timing cover. For the rear main seal you have to remove the transmission, clutch and flywheel.
                • Harry's E30
                  • 643
                  okay thank you, so that means the thing i need to know how to remove is the crank hub.
                  • Harry's E30
                    • 643
                    are they even necessary to replace?
