Between 1st and 2nd gear, it will randomly shut off, not all the time but some. Just falls on its face, no stumbling then dying. It dies the same way as if you pull the main relay.
Things recently replaced(last 10k miles):
CPS
main relay
alternator
distributor/rotor
Also, if I let it idle long enough with the AC on it will shut off the same way.
This problem only seems to happen on a hot day
I'm thinking:
coil? fuel pump?
edit: I forgot, it usually starts back up within 10-15 minutes, today it took 35. i LOVE this car right now.
CPS
main relay
alternator
distributor/rotor
I'm thinking:
coil? fuel pump?
