Oil, temp pressure sender block
  • CrazyB
    • 420
    I am looking for a distribution block for oil temp and pressure senders. I saw the one on bavauto and not sure how it works meaning where it attaches.
    Is there other options out there?
    Also where wood you guys suggest to connect an aftermarket water temp sensor?
    AutoCross Photos!!https://picasaweb.google.com/eugenes18t
  • reelizmpro
    • 9559
    I have one with a banjo bolt as well.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • CrazyB
      • 420
      Have one what? where do i get it?
      • reelizmpro
        • 9559
        I have the VDO adapter for the oil pressure sender. It only has 1 port though. You might be looking for a distribution block or something. Don't know if they have that for E30's.
        88 M3 - LACHSSILBER
        • SkinnyVT
          • Nov 2008
          • 391
          I was planning on plugging into the stock OP switch location, use a 12x1.5 to 1/8NPT adapter and then run a line to the fender to mount all the sending units.
          '86.5 325eis Track Ho | '08 128i DD | '04 Silverado Tow Vehicle
          • CrazyB
            • 420
            yeah i am looking for distribution block to connect both temp and pressure sensors to.
            • Mtriple
              • 3139
              I have this one: http://store.vacmotorsports.com/vac-...old-p1228.aspx
              Originally posted by Simon S
              • CrazyB
                • 420
                Looks Like I am going to go with temp sensor in the pan drain bolt and a the bav auto adapter for pressure, now just need to figure out what do for water. i was wondering if anybody used the bleeder screw on top of the thermostat?
                • brian52555
                  • 425
                  Hey,
                  leatherz.com sells what you're looking for. I bought mine off a local forum member, good stuff. I have yet to install it though.
