Fuel Pump Issues
  • beybedba
    • 517
    Fuel Pump Issues
    Do you really need to replaced the whole fuel pump assembly or can you just buy the fuel pump alone?
    what is the part # for the fuel pump alone? I've search online but all i can find is the whole assembly. BMW only sell the whole assembly.
    my car is a '90 325i. So it has the fuel pump assembly inside the tank.
    thank you
  • billybobjoseph
    • 213
    You can buy just the pump - try Pelican Parts ( www.pelicanparts.com ). You can also fit an aftermarket pump if you are willing to alter your pump mount a little on the bottom. Someone did a DIY on it if you look through that section of this site.
    • Lieutenant
      • Feb 2011
      • 14
      Pelican only offers early fuel pump models.
      OP, What was wrong with the one I PM'd you?
      http://cgi.ebay.com/ebaymotors/FUEL-...ht_4233wt_1037
      I am that, which is.
      • beybedba
        • 517
        i hate how the seller doesn't reply back on my messages... i'm losing patience... =D
        btw. did you have to modify something when you replace the FP?
        • billybobjoseph
          • 213
          Page 5 of the DIY section LEANE30's bit on putting in an aftermarket 255cfm pump for $60
          • beybedba
            • 517
            thanks you sir =D
            • billybobjoseph
              • 213
              No prob. ( oops $80 ) I installed that exact same pump in my 88 325is and am very happy with it.
              • pharow
                • Jul 2010
                • 1021
                The pump from the DIY section works great.
                '02 Outback wagon
                '87 325is 5sp
                '93 Kawasaki ZR1100
