Dude, you gotta post pics of that
Problem gone from bad to worse
Well tried the sazall with a standard Milwaukee metal blade, cut down to a shaft at the core which I assume is for the impeller. Then nothing, the blade wouldn't cut through just polished it. So i go to HD and get a Diamond tip blade and some evil looking blade called the metal demolition (I think), but neither will cut the shaft, they all cut through the housing like butter but none even come close to getting through.
I have no idea what to do now. Ive stripped all the bolt holes on the old water pump. tried the chain wrenches on the pulley idea, used the tool that bolts to the pulley an tried cutting the dang thing off. I must have the WP from hell or im missing something REALLY obvious, but as of today ive been stuck on this one step for over a week nowComment
I think if I was you I'd get a chain wrench around the pulley, get up in the engine compartment where I could put my foot on it. Take my 32mm open end wrench and a big pipe that fits around it as a cheater bar take that nut off.Comment
I've encountered this same problem... solution, tommy gun1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
Visit www.BimmerHeads.com for all of your 12 valve needs!Comment
FIXED, I finally beat the fan clutch, stuck an oversized bolt in the stripped holes in the pulley to attach the tool, then braced it on the frame. Emptied two cans of pb onto it let it sit overnight, then cooked the bolt with a torch, then hit the 32 mill with a dead blow. WOOOOOT no more fan clutch problem.Comment
