I just tested the voltage across the coil and it shows 0V with the ignition on?! There is still a spark when doing a spark test.....is this possible?
Also, forgot to mention that one of the timing belt covers has a stripped thread (on the engine block) so I can't screw in the bolt without retapping the block (you can see a slight gap):
Weird thing is it ran fine before the rotor broke. Is it possible I blew a relay when the rotor cracked?
