Hopefully some problem solvers out there that can help a brotha out:
I replaced the timing belt on my 91' 325i (in addition to pump, belts, tstat, cam seal, valve adjustment). The timing mark on the crank was ~1 tooth off from the corresponding mark on the cam....so I assumed the harmonic balancer must have slipped over the years and I adjusted marks to match (the car has ~140k and has never had a timing belt change). The engine fired up great after reinstalling everything, but had a strange 'knocking' noise that increased with throttle/speed. There was a slowly increasing loss of power over the next few drives. Took it to a (euro) mechanic and he said it didn't sound too abnormal (not piston slap), and maybe it just needed oil. On the way home, the knocking grew louder and the engine completely died mid-drive.
I got a tow back to the house, ripped everything apart, and found that the cam was extremely loose (wobbling about) and cracked the distributor rotor into pieces. I had removed the rotor already during the timing belt change, so I know it wasn't a preexisting issue. After replacing the rotor the engine still does not start
: Its definitely related to the mystery knocking (loose cam / rotor?).
-Spark Test shows a bright blue spark
-Spark plugs do smell like gas
-Engine cranks (shown in the video)
-No apparent vacuum leaks
-Stomp test doesn't yield any codes
-Engine worked fine after tbelt change, so it shouldn't be the crank sensor
-Maybe its that 50A fuse near battery? I think the 6-gauge wire feeds the ecu, pump, and injectors.
This situation is killing me, any ideas?
: Its definitely related to the mystery knocking (loose cam / rotor?).-Spark Test shows a bright blue spark
I'll try cranking everything to TDC in the morning and starting, maybe that will do something.
